跳转到主内容
加入维修社区 - 创建账户
A compact version of the HTC One, released August 2013.
Best way to maintain pressure to fix a broken ribbon cable?
Previously, I broken a LCD connector: Are LCD FPC connectors that fragile?
The result is that my screen was no longer displaying correctly.
However, I managed to make it work again. It seems to be a contact problem.
To recover the use of the screen, I did not have to put pressure on the broken part of the connector where the pins are visible (it was ineffective), but rather on the black part of the ribbon cable just before the connector. It also works if I put pressure on the golden part below the black part.
I tweaked it using a tweezer, but now I would like to know how to maintain the pressure permanently in order to reassemble my smartphone?
I do not have very sophisticated equipment. I tried with duct tape but it did not hold it with enough pressure. I thought of glue, would it do the trick? Below the golden part is the battery, so electronic components should not be damaged.
I have already made a huge mistake once, I prefer to ask your opinion on the best way to solve my problem rather than make a mistake twice.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
Obviously OP’s problem is long since solved (or not), but this was the top Google hit when I had a similar problem. My ribbon connector (for a laptop touchpad) wasn’t outright broken, but after being taken apart and reassembled it just wasn’t staying connected without my finger pushing down on it. It wasn’t so much broken as it was just loose.
Based on some other posts (people shimming ribbon/FFCs with various bits of plastic or cardstock) and some thinking, what I did was to take the ribbon cable out, cut a piece of electrical tape that was just the same size as the ribbon cable head, and tape it on to the back, the non-contact side. This makes the ribbon cable slightly thicker, so that when you stick it back in, the clamp is adding more pressure on the contacts. That fixed my problem, so I just wanted to document it somewhere on the internets in case it helps someone else.
这个答案有帮助吗?
得分 2
1条评论:
That's what I did with a Yaesu VX5r hand held 2 way radio, only I used 2 strips of Scotch tape, the same as you on the non contact side of the ribbon cable. You can also tape it down so it won't slide out of the connector as well. So far so good!
完成的
添加一条评论
There is honestly no really effective way to hold it down in complete honesty anything that you can use would only give you a temporary fix.
这个答案有帮助吗?
得分 0
添加一条评论
ive fixed quite a few devices during my time, and have run into this problem a couple times.
The most effective way to maintain the pressure, is to take a smaller flex ribbon head than the one you are fixing, and file it down on the end to a round. (so it doesnt damage the connector further.) after which, you apply it on top of the one for the screen, shimming it into the connector. the new head needs to be just the right size. if you do not have access to this, then you can cut down one of a larger size. just be sure to properly file it.
You can also use this as an excuse to tinker with your SMT skills, and try replacing the connector. (this is the easier SMT product to replace over the ICs.
这个答案有帮助吗?
得分 0
添加一条评论
I accidentally pulled my motherboard laptop off from the chassis while the touchpad cable was still taped to it so I broke the connector. I tried different ways to secure the touchpad cable going to the motherboard. I used kapton tape, electrical tape, and even gluestick (broke the plastic that holds the connector)!
Finally, I discovered a way to secure it for good. I cut a piece of cardstock with the same dimensions as the ribbon cable head. For the tape, I used gaffer tape to cover the connector and the cardstock. Gaffer tape is not heat resistant so I put Kapton tape over it.
This fix worked like a charm. The touchpad no longer malfunctions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Delgan 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 36
过去 30 天: 169
总计 9,665
