Why is my radio not turning on?
whenever i turn on the car the time will flash on then turn off and my radio wont start up
First thing to check is the fuse.
这个答案有帮助吗?
@col_panek This is more of a comment not an answer. Also, the op said the radio flashed, assuming there is power going to it
I never assume anything.
Check that fuse #28 (& possibly #39) in the passenger compartment fuse panel are OK. The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the fuse panel cover to gain access to the fuses. To remove a fuse use the fuse puller tool provided on the fuse panel cover.
Here’s an image from the owner manual to show you the fuse locations in the fuse panel.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 146
总计 7,471
3条评论
Did you push the power button on the radio?
由 Cameron 完成的
yes i did but still off
由 Tsoxmonto Tsokos 完成的
I have a 2010 Ford Focus SE radio won't come on What's . Show ever
由 jasonoverbey4 完成的
