跳转到主内容
Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
108 个问题 查看全部
Remove ear cup / cushion JBL Everest 700
There is something rattling in the left ear cup of my JBL Everest 700 headphones. Past the one year warranty so I figured I would take it apart and see what it is to try and fix myself. Couldn't find any tear down instructions anywhere. Any idea how to remove / take apart the ear cup? I can't even figure out how to remove any portion of it. Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The ear cup is kept in place by by 6 clips (see the bottom picture of this ad for replacement cups). After seeing that picture I was able to remove the cups by applying pressure near the edge of the cup with my fingers. There was some glue residue from the edge of the outer padding, but not much. I would not recommend using any sharp tools, as you will quickly damage the outer layer of the padding.
Putting the cup back in place was easy.
The linked ad is not meant as a recommendation, it just helped me figure out which part should be removable. I have not yet bought any replacement cups. In my case, part of the edge of the outer layer became unglued, I just needed to separate the cup from the headphone to apply some new glue.
这个答案有帮助吗?
得分 0
4条评论:
Please note: this is valid for a Everest 700 Elite.
完成的
Hey jan, waar bij de earcup heb je druk toegepast?
完成的
The edge of the cup is where the soft material ends. Be careful not to damage that soft material, so avoid sharp objects. I used a finger nail to get a little bit of space, and once you have some space, use your finger tips to go around the entire cup step by step.
Apparently not all cups are mounted with clips, some are glued. I have no experience with those, it seems they can be exchanged as well.
完成的
Some kid dropped mine so now the left side is quiter than the right and it's really annoying, so I'm wondering if someone can help me with this
完成的
添加一条评论
添加你的答案
Christopher Dale 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 7,350
