Where can I find a replacement USB charging circuit board for UE Boom?
Due to corrosion, I need to replace the USB port, along with the circuit board attached to it from my UE Boom. I can't seem to find the part anywhere. There are plenty of numbers on the circuit board, but they all seem to be random. I was hoping someone could either tell me where I can find the part, or give me an alternative solution. I'm trying to avoid buying an already broken donor speaker for the part. The board does say that it is manufactured by Logitech.
Here are the numbers:
TP503
TP502
TP501
3613C
E153302
94V-0
USB_1417-002
CN501
5条评论
I need to buy this item but i don’t know how
由 safimatihullah 完成的
Not charging properly
由 Kannu Dumka 完成的
How to purchase charging circuit board model s-00122
由 Kannu Dumka 完成的
Anyone just added another port to charge the battery? Then connect direct to the battery
由 lyndonjc 完成的
@lyndonjc
Doing that may be a bit dangerous because you would be bypassing the battery management circuits which prevent the battery from being overheated or or overcharged whilst charging
由 jayeff 完成的
