跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 个问题 查看全部
Why did my Barista become unresponsive after losing steam pressure?
A while back, on one or two occasions, my Barista would lose pressure in the middle of steaming milk. I decided to descale it before using it again and see if that fixed the problem before thinking more drastically. However, when I turned it on next to begin descaling, the machine is completely unresponsive. I tried it in multiple outlets, and also tested the steam wand and portafilter separately. No sounds. No heat. I just read in another question's answers that I should test the fuses above the boiler. Would that seem like the next logical step?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Yes; if you ran the boiler empty (happens naturally during steaming) but didn't refill it before heating again then you may have overheated the machine and tripped the thermal breaker (fuse) on the top of the boiler. I would check that fuse first.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maggie Gervais 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 99
