跳转到主内容
Panasonic ARC ES-LT3N was released in April 2015. The sure-grip handle provides ergonomic comfort, and advanced 3D Multi-Flex Pivoting Head that moves up-and-down, side-to-side and back-and-forth to conform closely to facial contours for more efficient shavings.
3 个问题 查看全部
Why does my razor keep getting hot?
Recently my razor keeps getting hot when I try to shave, what do I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
If the outer foil is getting hot check to see if it is damaged or deformed. If so it needs to be replaced. Also, the razor may not operate if it is in an environment that is lower than 41 degrees F (5 degrees C).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Eric Mosley 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 270
