跳转到主内容
The Nikon D5200 is an F-mount DSLR camera with a 24.1 megapixel DX-format CMOS image sensor. The D5200 has a maximum resolution of 6000x4000 and is capable of 1080p video recording.
31 个问题 查看全部
Problem with image size
A friend has this camera and so do I. We both have the image size set on RAW and L. My photos have a high resolution of 6000 x 4000 and hers are at 640x427. We cannot figure out why her photos are so small. Would this be a camera defect?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
When she uploads the photos in Lightroom, all come in at 640x427 297Kb. She is not using video.
完成的
Your Lightroom is probably set wrong. That's thumbnail size. Change her upload settings to full resolution.
完成的
添加一条评论
1个答案
已选择的解决方案
That resolution isn't even possible with that camera. However, 640x424 is a supported video resolution. Are you sure your not looking at the video setting? If not, what is the resolution of your pictures based on what your computer says? Good luck.
这个答案有帮助吗?
得分 1
3条评论:
Also, you need to try a system reset on the camera. It should be in the menu with the wrench.
完成的
I might not have the size exactly right, but all of the photos she uploads into Lightroom are a small pixel size, and about 297KB. All the settings on the camera look right, image quality is RAW, and size is L. But the photos upload very small.
完成的
Something is wrong. What resolution is the image size set to?
完成的
添加一条评论
添加你的答案
abutts22 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 218
