跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
How to fix screen issues after screen replacement?
Hello, earlier today I put a new screen on my iPhone 5c to replace a cracked one that caused a similar problem that i am experiencing now. After i finished, i noticed that the colors were kind of dimmed and the left side is black (see picture). Any advice on how to fix this? I also noticed that the screen was a little lifted from the surrounding casing on the phone. Could it be a bad battery? The screen is still responsive. Picture
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi, the picture that you provided would indicate damage to the LCD. The solution to this problem is it carefully install a new screen assembly. This will solve the black part and any funny colors. As far as the battery, does it appear to have any wear marks on the battery from swelling and touching the LCD metal bracket? This would indicate that you need a new battery. If you have a voltage tester, you can remover the battery connection and test the battery for proper voltage.
这个答案有帮助吗?
得分 2
5条评论:
TL:DR - Replacement screen was either improperly installed or the internal LCD came damaged like that.
OP could you post a screenshot of the inside of the phone particularly at the battery? Sometimes this causes the screen to be pushed up like Nick said.
完成的
So should I buy a new LCD Digitzer ? And I will post a picture of the internals when I get home.
完成的
Yeah, the one installed right now is physically damaged and needs replacing to fix.
完成的
I am thinking about just having it professionally repaired
完成的
添加一条评论
It is probably faulty screen. Aftermarket screens for 5c are notoriously bad. I tried a 2 from ebay and 1 from Amazon with the same result. Finally bought one from iFixit and to date (5 months later) no issues.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jackson Sindaco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 58
