跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Phone Not Turning On
My phone got off automatically! For some time only samsung logo was seen after that there is nothing! I tried changing battery bt didnt work! There is nothing while charging except phone gets heat up.! Did i lost it ! please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you tried getting to the boot menu of the phone by holding the Volume up button and the power at the same time.If the boot menu is working try to do hard reset or try to restore it to its original firmware via kies.
-Hard Reset
1. Hold the Volume Down button
2. Press and release the Power button
3. A menu will then appears
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6 Select Volume Up for YES and Volume Down for NO
-Guide on restoring original firmware with kies
http://www.samsung.com/ca/support/skp/fa...
这个答案有帮助吗?
得分 0
2条评论:
Already tried
完成的
Phone is not starting!!!! So unable to hard reset it.
完成的
添加一条评论
添加你的答案
Kashif Abdullah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 96
