跳转到主内容
MacBook Pro 13寸显示器版本
9741 个问题 查看全部
When I power it on it freezes and displays only a question mark
When I power it on it freezes and displays only a question mark (a flashing question mark) Can anyone please help me with this, I tried starting in safe mode but no help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
What year model is this computer? There are some issues with some of the Hard Drive Cables which could also be your problem here.
完成的
See if you can read off the systems serial number on the bottom cover and plug it into here: EveryMac - Lookup. Then paste the systems URL here for us to see.
完成的
Thanks Dan I didn't even think about them possibly not knowing what year model they bought. Thats not sarcasm either.
完成的
添加一条评论
2个答案
It either has No O.S. or Cant load O.S. Due to a HDD failure
这个答案有帮助吗?
得分 0
1条评论:
More likely the HD's SATA cable, I would start there.
完成的
添加一条评论
Or a hd cable failure. But we need the model number to help you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
3D man 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 46
