My Laptop can not produce sound when I connect headsets
My laptop can produce sound, disregarding the fact that i updated the sound-drivers when i i connect the headsets, but the pc's speaker does, but it dos not work with headsets.
Hi,
Have to ask, you did try another set of headphones didn't you?
It may be that there is a faulty or loose audio output socket in the laptop.
Unfortunately it appears as though the socket is directly mounted onto the motherboard.
Here is a link to the service manual for your laptop. On p.62 it details the necessary pre-requisites and then the procedure to remove the systemboard. You may not have to go this far to initially prove whether the socket is loose or not.
If it is deemed to be faulty then you will need to have the necessary SMD (surface mounted device) soldering skills and tools to remove and replace the socket.
If this seems to daunting for you to do, contact a laptop repair service and ask for a quote to repair the socket.
If you really wish to use headphones and a repair is not an option you could try this alternative solution.
Hopefully this is of some help.
这个答案有帮助吗?
thanks for A TIP.. will do that
Check your sound settings in "system preferences". Under output select "external headphones?
这个答案有帮助吗?
will try that, thanks for a tip
i tried that but nothing worked
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 155
2条评论
Hi, When you plug a headset into the earphones socket does it disconnect the sound from the main speakers?
由 jayeff 完成的
yes, that's what happens
由 BERNARD KATHEWERA 完成的
