跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Bluetooth connect / disconnect loop
Hello, my s6 is having an issue with bluetooth. It will connect to an item then disconnect from it then connect again then disconnect again. Then after it connects and disconnects 2 to 3 times it will connect but no sound will play through the device, only a clicking noise can be heard. I tried clearing the cache, rebooted, forgot the device and reconnected to it, cleared the cache from the boot menu, and as a last resort factory reset. I've tried all the steps I could find online. I took it to us cellular and they suggest either pay 175 for insurance to get a replacement or buy a new phone. The tech said it could be a hardware issue.
Is there a step I'm missing? If it's a hardware issue, what should I replace? Any help or advice is greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Is it possible to change the bluetooth receiver or update bluetooth version? If so, which board would need replaced? Or, what can I do to fix the problem? Need some sort of direction please. I've reflashed the phone and still having issues, which is leading me to believe it's a hardware issue...
Thank you
完成的
添加一条评论
1个答案
- Place your device into airplane mode temporarily to reset all wireless connections.
- Go to your device Settings -> Location -> Improve Accuracy -> Disable Bluetooth Scanning
- Go to your Application Manager, and Locate the Bluetooth ......Continue Reading on VARIFIED SOLUTIONS
这个答案有帮助吗?
得分 0
1条评论:
Thank you for the reply. I tried that and I still get the off them on loop. There's not too much delay between turning on and then off and then back on again, I'd say about 3 seconds on, 3 seconds off, and repeats this way.
完成的
添加一条评论
添加你的答案
Nate 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 932
