跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 个问题 查看全部
Original 3ds, blue light turning on and then turning off
Hi there i have a 3ds CTR-003 model and yesterday i tried to turn it on but the blue led indicator flashes for 1 or 2 seconds and the console does not turn on it does not make a popping sound ether i have no clue what it might be .
Update (05/12/2017)
i installed A9LH susceffuly and know its turning on but it keeps spasing out always going down i dont know what it might be any ideas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Did you by chance try to install A9LH or Luma before this happened?
完成的
添加一条评论
1个答案
最有帮助的答案
This is a brick, unless you have a NAND backup then you may not be able to easily recover it.
If you have a NAND backup then follow this guide and set up your SD Card with the NAND Backup and the GodMode9 app, boot into GodMode9 then install the NAND.
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
添加你的答案
hugoifer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 3,230
