跳转到主内容
加入维修社区 - 创建账户
Wont turn on after new battery and cleaning the motherboard
Hi, im looking for a solution for my gameboy Micro (now i have 2) ones works perfectly and the other one wont turn on at all, tried to use the same good battery i have (didn't work), when i plug in the gameboy to the wall charger the blue leds blinks once and thats all
tested the screen and speakers on my good gameboy and they work so the problem must be on the motherboard itself
any solution will be very appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
You should get a Multimeter and check if the motherboard have been short-circuited, maybe you had some static electricity in you when you touched the Gameboy's motherboard which ruins a motherboard. I advise you to get a Multimeter and check the motherboard still gives the right positive and negative charges.
Versatile multimeter with all the right functions for basic electronics troubleshooting.图片
产品
Digital Multimeter
$59.95
这个答案有帮助吗?
得分 0
添加一条评论
First, I would try a new battery. They start at around $10 for 460mAh or $15 for 600 mAh. But use your known good battery from your other GBM first.
If the problem persists, you most likely have a bad cap or resister on the motherboard. You'll have to test for continuity with a multimeter.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cesar Melendrez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 824
