跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 个问题 查看全部
Does iFixit 9.5 mm enclosure fit in the iMac 27"?
Does anyone have experience on installing the iFixit optical bay enclosure (9.5 mm) in the iMac 27" chassis?
The main question is; does the iFixit 9.5 mm SATA bay enclosure fit in ? I'm planning to replace the optical drive with an SSD.
Thanks.
-Kim
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Yeah you can do that, check this MacRumors thread for some tips.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for your answer. Yes, there seems to be discussion about the possibilities in the discussion forums, but I haven't seen any that actually confirms that the iFixit enclosure actually physically fits in as the replacement for the original SuperDrive.
完成的
Well if you read the thread you'll see the OP there actually did it
完成的
添加一条评论
添加你的答案
mjobanx 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,494
