跳转到主内容
加入维修社区 - 创建账户
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Screen not responding to touch
Cannot unlock or power off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You need to be more descriptive because these could be two separate issues and instead not be related together.
Cannot unlock which I'll imply this time is the touch screen digitizer needing to be replaced.
For power off it could be related if you mean you can't slide to power off due to bad touch screen or it could be the power button cable being cut causing you not to be able to use the power button.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi, the easy fix would be to perform a hard reset. Hold the home button and power button for up to 30 seconds or until the devices turns off and back on again. If the touch starts working again, then great! If not, you will need to perform a digitizer repair. Remove your current glass and install and new screen. This will then fix your issue. iFixit has lots of guides on how to repair the glass digitizer.
这个答案有帮助吗?
得分 1
2条评论:
It worked on my iPad 2. Thank you
完成的
any idea if it won't respond to a new digitizer?
完成的
添加一条评论
Great answer from Nick. Usually hard reset solves the problem for this model
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony Spooner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 4,305
