跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Anyway to repair the copper traces on motherboard?
hi to all,
I was trying to replace charging chip on an iPhone 6. In the past I use to solder the laptop and desktop motherboards but nothing this small as the iPhone 6 motherboard.
Anyway, I used the heat gun, some flux, and everything seemed ok but later under the microscope I noticed that there are few round circle pins missing. I probably didn't heat the motherboard enough and while removing chip I probably tore the trace and removed with those small copper pins.
The question is: Is there anyway to repair them? I presume that the where somehow connected to the copper via's inside the motherboard.
Is there anyway to solder/glue them back again?
Update (04/01/2017)
here it is attached, and sorry it is not iphone 6 but iphone 6s. According to the schematic pins are A4 and D4
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Most of the time those are dummy NC pads. Post the image.
完成的
添加一条评论
3个答案
已选择的解决方案
Where you using a heat gun or a hot air station? The difference is enormous. You cannot use a heat gun to do micro-soldering.
Depending on where the pads are and what they connect to, it is possible to repair them. As @gigabit87898 says, you need to confirm if they are N/C (not connected) or not. If you have schematics and boardviews (and honestly, if you are soldering stuff on an iphone logic board, you really should have these), then you should be able to figure it out.
In order to run jumpers, you will need very small wire (at least 42AWG), a microscope (or really good young eyes ;>) and fine point soldering iron tips on a temperature controlled soldering iron/station.
Otherwise, you should look for a repair shop that specializes in micro-soldering repairs.
这个答案有帮助吗?
得分 2
3条评论:
I guess having young eyes is good explains why most of the time I just use my eyes instead of the microscope haha.
完成的
pros kit ss-969 with temperature and airflow control
完成的
The two pads missing are D4 and E4 and the connections must be restored.
You can jumper D4 to R0902 but E4 is more complicated. It goes directly to the PMIC (U2000), the CPU (U0600) and Chestnut (U4000). However, there is a probe point (PP1021) right next to U4000 that is part of the NET. You could scrape it and connect your jumper there.
完成的
添加一条评论
What ones are they? They could be useless like n/c pins or they could be important. Post a picture from the microscope so we can see them.
这个答案有帮助吗?
得分 1
添加一条评论
Follow the schematics and use jumper wire
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
myth 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 6
总计 1,626
