跳转到主内容
Repair guides and support for the third generation of C/K pickup trucks.
28 个问题 查看全部
Put a short tail tranny in place of long tail
I changed tranny on my 84 Chevy 305. I put a350 tube short tail trans in place of 350 long tail. Had to cut a drive shaft to fit cause short tail was for a car i guess.now it's like my brakes are on .trans got hot and won't run
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Look at your rear end pull the differential cover off lift up the rear axle inspect very carefully for good clearances to make sure the tires spin (in nuetral of course) make sure the ring gear isn't wedged into the pinion gear. also it certainly sounds like you cut your drive shaft too long perhaps, if so remove a little bit more and try again, dont forget to make sure the driveshaft is balanced and weighted you could do severe transmission damage if not possibly break the tail shaft housing and or tail shaft/planetary set
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ted 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 419
