跳转到主内容
加入维修社区 - 创建账户
许多Windows平板电脑的维修指南和拆卸信息,来自各种制造商。
How to Recover Data after installating New Windows
Hello Friends,
I have a problem and I hope anyone can help me out!!
Today morning, I upgraded Windows 7 to Windows 10 and before performing the upgradation process, I took backup of my C drive to other logical drives. But after completing the Windows installation process I found all the logical drives empty. I had installed Windows many times in my life but never faced this problem. Please help.
Thanks in Advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
Do not move anything around or transfer anything to the drive you backed up to! And if you can, disconnect the drive. You'll need to find some good data recovery software. I cannot recommend any myself, but I presume @jayeff might!
完成的
Thanks, George A for your quick response. I also want to ask why my data got vanished from the other logical drives. I was wondering that only C drive data will be gone.
完成的
All local disks are formated when upgrading windows. And just to be safe, I like to unplug any other drives anyway.
完成的
Any suggestion for the recovery software?
完成的
Hello Liza,
I agree with George A and altbell you can download a data recovery software to get your lost data back. Now day’s there are number of data recovery tools available you can try any of them. From my side I can recommend one data recovery software which my sister used to recover her lost data name as Stellar Windows data recovery software. You can try your luck with this tool.
完成的
添加一条评论
2个答案
Hello people: I have done many windows 7 to windows 10 and in the upgrade the install has left all my programs and data intact. With the upgrade as it goes along you have choices to keep your data and apps and continuing installs windows 10 with all your My Documents files intact. It only installs to the same partition so in no way would it look or destroy other partitions unless before the install you extended your c drive to be the whole drive and delete then extend your c drive. Even with installing Windows 7 and before no other partitions were touched unless you did it. I am confused how Windows by its self did this. But looking on the internet you can find recovery software to recover your data with one thing to remember. Do not use or install or even run the computer until you remove the hard drive and use the software with another computer to recover your data. Good luck
这个答案有帮助吗?
得分 0
添加一条评论
If you can plug in the HDD into another computer I use R-Studio.
http://www.r-studio.com/
If not I would recommend Active@ http://www.lsoft.net/bootdisk.aspx which allows you to create a rescue boot disc.
Please remember that the more you use the HDD that has the deleted on it the more likely that it will be over written. The larger the drive the more of a chance you have.
There are free programs out there but these are the two I have used for my computer business for over 10 years and have recovered most data.
Also you can use the free HDD imaging software Reflect to image your HDD as a backup once the data has be recovered.
https://www.macrium.com/reflectfree
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 116
