跳转到主内容
Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
2702 个问题 查看全部
The iFi does not power up - the internal fuse is fine.
I have a Klipsch iFi 2.1 Speaker System for iPods (Discontinued). It has been off for a few months and now it does not power up - no power on LED glowing on the back panel and the iPod dock control does not light up either. The internal 2A fuse is fine, and 115V AC is going into the fuse clips. I can't go any further in without electricueting myself.
Has anyone else experienced a dead iFi and sucessfully troubleshooted it?
Thanks - Mike
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
mmano46028, congratulations on your repair. All you have left now is to change your comment to an answer so that we all know that your "case is closed" congratulations, good job.
完成的
添加一条评论
4个答案
已选择的解决方案
Case closed!
这个答案有帮助吗?
得分 0
1条评论:
Cool. Thanks.
完成的
添加一条评论
最有帮助的答案
Yippey! Got it working by replacing the 25V 4700pf capacitor and 4 of the 35V 4700 pf capacitors. The original caps had bulging tops, so replaced them with true audio grade caps (Nichicon brand). I found a post on the Klipsch support website.
这个答案有帮助吗?
得分 2
4条评论:
Do you mind if you can post the link to the Klipsch support website post?
完成的
I don't mind - please do to help other people with the same problem....I can't live without my Klipsch iFi!
完成的
Sorry mmano46028, what I meant to ask is if you still have the link to the post on the Klipsch support website on this topic that you found.
完成的
I tried replacing the 2amp fuse, which was visibly burnt to a crisp, and as soon as I powered it on it popped the fuse again. My next step is to replace the capacitors. I can't believe I was so ignorant the first time around. When I saw this post, I went back to check the capacitors and at least 3 of them had bulging tops. I really appreciate the tip here! I'll post again when I've given this a try. Thanks.
完成的
添加一条评论
On mine, the fuses would blow in just a second. since they are slow blow, that makes sense. the real problem was that the MOV1 or varistor (the little round yellow transistor next to the fuse) was blown, and was creating a short circuit.
I looked into getting a replacement for TVR14181,
but finally decided to do the best thing........
cut it out with snipes and use a surge protector that
had the same functionality. device works fine!
这个答案有帮助吗?
得分 0
添加一条评论
I replaced the capacitors as mentioned in the comments above however I’m still not getting any sound. fuse is not blown either. Any ideas what else it could be?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mmano46028 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 7,053
