跳转到主内容
Released March 2016, the Rift CV1 is the first consumer-targeted virtual reality headset by Oculus.
33 个问题 查看全部
How to fix HMD disconnection?
My Oculus Rift headset is constantly disconnected, and the "We can't find your headset..." notice will pop out, I have tried everything on the software end including setting usb power management and got the officially recommended Inateck PCI-E USB card, which didn't help either. The headset will disconnect randomly and also when I give pressure on the top of the device, especially on the top left nearby the HDMI plug. Wondering if this is caused by the hardware defect and it would be highly appreciated if you could tell me how to fix it. Thank you very much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like a defect. Like a loose wire. My friend had one that had the same problem and he just sent it in under warranty, is your's under warranty?
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Bocheng Lin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 10
总计 1,576
