跳转到主内容
The third iteration of the 10.1 inch Galaxy Tab tablet.
126 个问题 查看全部
Charging port not working
I changed the charging port because when I would plug into the port it would come up on the screen the a USB connection would not connect. When I wiggled the plug some times it would work. I inspected the port and it was bent and starting to come apart. So I got a replacement port and installed it but the tablet will not come on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Could you elaborate more on whats happening? It might not be your charging port but your battery. But please elaborate, what happened before. Why did you replace the charging port?
完成的
Hi,my tablet dont charge,y change the battery,the ruban of usb and a motherboard from ifixit,it open and work but not charging why.
tank you.
完成的
添加一条评论
1个答案
已选择的解决方案
Hello Jesse Ward your problem here might be the battery I had the same problem happen to one of my costumer's and I just simply replaced the battery and it worked but if you have a other tablet the same extract I would recommend testing out the battery with that one and the charging port just in case. Best of luck Jesse I hope this helped a little.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jesse Ward 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 7
总计 1,071
