跳转到主内容
问题已关闭
Setup fails to find printer, printer and Windows says connected
Setup fails to find printer, control panel and Windows shows it is connected. I can print a test page from Windows but the Brother software install does not find the printer whether it is connected over wifi or USB. I have spent four hours on this, checked firewall and anti virus settings, searched online, etc. Any suggestions would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I figured it out, finally. I had to get the IP address from the control panel on the printer and go into the custom network setup in the Brother installation package and enter the IP address. Then it finally found the printer and installed the software. It was weird that both the printer control panel and Windows said the printer was connected but the Brother install wizard couldn't find it. Anyway, It is now setup and working. Hopefully this information might save someone else the 4 hours I spent on this.
完成的
添加一条评论
2个答案
已选择的解决方案
这个答案有帮助吗?
得分 0
添加一条评论
Gloria, could you reprint your answer in the "Answer this question" box? Otherwise, it appears on the main "Question" page that your question hasn't been answered at all...
这个答案有帮助吗?
得分 0
1条评论:
Done. I did that at first but the site suggested that I should post it as a comment. Hope this helps.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 36
