跳转到主内容
Coffee brewmaster released in 2013. The Keurig K40 is a k-cup compatible coffee maker.
31 个问题 查看全部
leaking water out bottom of coffee maker
my keurig k40 is leaking water from the bottom
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
There are several possible causes.
The easiest to check and fix is that the holding tank is cracked and leaking.
Its also possible that the needle is clogged up with grounds, you can use a paperclip to clean out the needle.
It could also be that something is broken inside the which is difficult to diagnose without taking it entirely apart.
这个答案有帮助吗?
得分 0
添加一条评论
The bottom needle broke off with the plastic it it modes to.
Is there a replacement part available?
这个答案有帮助吗?
得分 0
添加一条评论
There are some easiest ways to fix this problem:
Faulty O-Ring
Inspect The Water Reservoir
Keurig Needs To Be Descaled
Broken internal Part
you can see all the solutions on this guide How to Fix Keurig Leaking Water/Coffee From Bottom
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lcm348 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 16
总计 4,763
