跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Display spoil after refurbish lcd.
Hello, recently when I'm doing refurbish 6s/6s Plus LCD I found out that everytime I done cleaning the oca on the LCD after removed the polarizer then the ribbon spoil. I found it when I'm doing the last check before put into the machine. The problem is when I touch the LCD ribbon or trying to flip gently the display gone strange. I was wondering is it the oca remover caused it or the static. Please help!
Update (03/27/2017)
This is the problem when you touch the flex or flip it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
If the problem not serious the LCD still usable.
完成的
What does the LCD look like exactly? Can you post a photo? When you remove the polarizer the static line at the top is usually also removed. Which causes a ghosting effect until it is re-applied later in the refurb process
完成的
Question updated. Is this what you called it ghosting effect?
完成的
I used 8333 and zippo to clean the oca glue after removed the polarizer.
完成的
添加一条评论
1个答案
已选择的解决方案
You are better off posting this in the iFixit Pro Talk forum where pretty much business owners and etc talk to each other. There are many good LCD refurbishers on that forum that go in depth about these issues and the solutions to them.
https://talk.ifixit.com/
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ong Kim Sheng 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 147
