跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Will not turn on after attempting to change backlight fuse
Hello,
First, my screen was black with a flashlight showing the computer was on. I determined the back light fuse was blown. When I tried to desolder it, I shorted to nearby component. The motherboard was not unplugged from battery.
Now, absolutely nothing happens when I press the power button. Can anyone you please point me to where the problem is likely to be now?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Uh, Charles...there's usually a _reason_ fuses blow. Their purpose is to save power supplies and upstream components. Therefore, there was probably a short circuit downstream from the fuse to begin with. Failing to remove power from the unit before applying a soldering tool was a _major_ malfunction! At this point, the problem could be a blown component / circuit trace anywhere in the system! Good luck...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Charles Kensington 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 82
