跳转到主内容
加入维修社区 - 创建账户
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
FN key does opposite
i have a toshiba sattelite with a strange keyboard when i press a key with two options (FN -normal) it it only does the FN but i didnt press fn and when i press FN i get the normal options
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If your saying when you press fn it does normal but when you dont it does fn? if thats teh case thats normal. Nothing strange there. Just something that different between manufactures.
这个答案有帮助吗?
得分 0
4条评论:
i have this issue since last friday berfore then it was just fine
完成的
You probably change a setting or something. If it still works and it doesnt affect anything. Why does it matter. The f keys arent used often anyways.
完成的
it does matter because its the numerical part of the keyboard 1-0
完成的
oh ok. You got windows 7 or 10? if its 7 go to control panel then find keyboard and see if there is an option there. if you have windows 10. Check settings and look for a option. If not check control panel on windows 10. There might be an option to change that. Have you recently messed with any settings or anything recently?
完成的
添加一条评论
添加你的答案
pascal molenberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 136
