跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Fingerprint issue in setup
Please see the following pictures.
Fingerprint works in certain parts of the setup.
Any solution?
I did restore the software.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
8条评论:
Could you please explain the question a little better. Maybe I can help you
完成的
Ok so my iPhone 6S Plus old screen was working fine but sometimes was flickering around the corners, so I decided to change my screen like I did myself because I'm a technician so I tried around 5 screens and I realized those screen were not good quality so today I got another screen so the fingerprint was unable so I disconnect the screen and connected again and works so I went to fingerprint setup to add a fingerprint and it works but in order to complete the setup the next page was blank as you can see the pictures.
Any solution?
完成的
@albertoh did you do anything else besides opening your phone and trying to setup the fingerprint? I mean hard reset or something else.
完成的
Have you Recover the iPhone through recovery mode.
NOT settings reset ?
完成的
If not, I can tell you how to enter recovery mode
完成的
显示更多的3条评论
添加一条评论
1个答案
how to fix fingerprint gray out on iphone 6?
这个答案有帮助吗?
得分 0
1条评论:
Try to replace home button extension flex cable, but use the original home button or it will never work.
完成的
添加一条评论
添加你的答案
alberto houtmann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 157
