Ipad keeps shutting on and off after Digitizer Replacement
I just replaced the digitizer on my Ipad Air, after a reboot the Ipad now just repeatedly turns on and off without stopping, completely blocking any input.
I tried using the old digitizer, using a smart cover in any configuration possible, and disconnected the power button. None of it worked. When I press the power button I am able to hear that it shuts off/on once "more".
Any ideas what the problem could be?
My guess is damaged home button cable which has the hall effect sensor on it / damaged home button connector and/or misplaced / missing magnet(s) in the iPad.
由 Ben 完成的
Since the previous digitizer has the same issue now it shouldn't be the digitizer right? Is there any way to test the magnets? Or check them visually?
由 Carl Carlson 完成的
Oh. I didn't think it would be apple logo boot looping.
由 Ben 完成的
It's not, It was stuck at the apple logo then I put it in recovery mode and reset the device, now it is stuck at the language selection screen. It is NOT rebooting just switching on and off between display lock.
由 Carl Carlson 完成的
