跳转到主内容
发布于2013年11月22日的微软第三代Xbox游戏主机。
Power brick orange until I plug in the console
When I plug the power brick without the console an orange light is on, in the moment I plug it in the console it shuts down. I tried using the power brick with another console and it worked fine, and the other power brick did the same on my console. Any clue of what could be the problem?. I was wondering if the console has any fuse in it or some internal voltage regulator or similar, or maybe the processor or the motherboard are broken.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
The power adapter has a built-in shut off switch that disables all power when a surge, overload, or short is detected. Since you have already tried a separate power adapter (one that was confirmed working), and it does the same thing you most likely have a problem with the internal hardware of the console.
Have you tried unplugging the console for more than 30 minutes so it completely loses any voltage and (more or less) resets? This may solve your no power problem.
You can also check this out. It has helped me before in the past.
https://gamersrepair.com/index.php/troub...
这个答案有帮助吗?
得分 1
1条评论:
Can you tell me where this overload or short is detected on the PSU as I would like to troubleshoot.
完成的
添加一条评论
Looking at the if in the webpage you passed me it appears that the problem is in the motherboard. Thanks a lot for the hep!!
这个答案有帮助吗?
得分 0
2条评论:
Can you relink that page?
完成的
Hi,
I have recently had this problem and the link doesn't exist anymore. Is there a specific thing that is faulty on the motherboard? I'm wondering if it's something that i can fix myself? I would really appreciate if you reply :)
完成的
添加一条评论
添加你的答案
Javier Baizan 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 31
总计 40,742
