跳转到主内容
SodaStream Source is a new way to create soda in the comfort of your own home that allows you to personalize your beverage and make only the drinks you want, avoiding all the extra bottles.
22 个问题 查看全部
Why is the lever not moving?
When I position the bottle and push on it the lever does not move.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Make sure the bottle is inserted correctly. The bottle should be inserted and then pushed back, it does not screw in. Also, the nozzle tab may be in the incorrect starting position. The tab should start angled away from the bottle.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alexandra I Curtis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,217
