跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Problem with screen after replacement
I had a customer who had dropped his phone resulting in an expanded battery and damaged screen, both of which I replaced, and the phone appeared to be working perfectly. A few hours later he sent me some photos of what the phone looks like now. The brightness is low and the screen appears to have a pinkish hue, at least from what I can see in the photos. I've never had this problem before, is it just a bad screen? Or something else at play?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
So I replaced the screen, and immediately after replacing, I noticed that even though the screen was functioning, the 'end call button' was more pinkish than red, and while the front camera was working, it also appeared to be slightly off colour. I think the likelyhood of having two faulty screens is pretty low, considering the hundreds of repairs I've done, I only very, very rarely encounter bad screens.
完成的
添加一条评论
3个答案
最有帮助的答案
Its ether the LCD you put in was bad or it could be the cable connection on the motherboard which is a hard if not impossible fix I haven't ever had this problem b4 so I don't know exactly but just my thought thx
这个答案有帮助吗?
得分 1
3条评论:
I wouldn't say impossible to replace a FPC LCD connector on logic board there are people who do it.
完成的
Yea but it requires a lot of skill to do it your normal person couldn't do it sorry
完成的
Actually after looking at the pictures again it looks like a bad backlights built into the LCD I would try putting a new LCD in and see if that works thx
完成的
添加一条评论
Did you try a new lcd? Could just be a defective batch or the connector could be bad. Check the connector on the logic board too.
这个答案有帮助吗?
得分 0
添加一条评论
geralmente é o mal posicionamento do conector na placa lógica. colocado de forma indevida ele causa chuvisco, apagões e até mesmo o chamado touch fanstama.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 123
