跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
6s plus losing Touch ID after screen replacement.
I've replaced many iPhone screens, transferring the button to preserve the Touch ID, but this is the third 6s+ that I've replaced and all three have failing Touch ID, even with the original button. Is there something unique about the 6s+?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you checked the ribbon that goes from button to the logic board?
完成的
添加一条评论
1个答案
I have done quite a few 6s Plus's and have never had an issue with Touch ID so as far as I know there are no unique quirks to them when it comes to the home button other than the usual (don't damage the ribbon cable, remove battery and drain power before removing connector ect.)
Are you using OEM or aftermarket screen? The home button cable is built in to the screen assembly on the iPhone 6s Series and the aftermarket screens frequently have issues so if your using aftermarket screens you may need to switch to OEM to avoid this issue.
Also make sure the cable is not damaged and is seated correctly into the board connector, if the connector is not quite fully connected then you will get the click function but not the Touch ID.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Garrison Babbitt 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 159
