跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
No WiFi or Bluetooth
I am working on a MacBook Pro 15" Retina early 2013. There is no Wifi or Bluetooth.
  • The Wifi icon says "No Hardware Installed"
  • The Bluetooth Icon says "Not Available"
Troubleshooting already tried:
  • Tried new screen with new antenna cables
  • Tried a new airport card
  • Tried battery pull
  • I also have tried PRAM and SMC resets
I'm trying not to have to reinstall software and back up old software.
Does anyone have any ideas as to what else I can try?
Thank you for your time
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Was there any signs of liquid damage?
完成的
actually just got it fixed, it was the flex cable that connects that board to the main logic board, unplugged it and plugged it back in.
完成的
添加一条评论
1个答案
最有帮助的答案
Before you alter the systems drive how about creating a clean bootable USB thumb drive with the same or newer OS. Follow this guide: How to create a bootable macOS Sierra installer drive.
Once you boot up exit the installer and then see if WiFi works going into the preferences setting. Is that working? If not you have a problem within the logic board power services powering the Airport board. If the external drive works then you have a messed up OS install.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Amber Savoy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 140
