跳转到主内容
加入维修社区 - 创建账户
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
Why isn't my phone charging
Its been plugged for 24hrs now n its going down in battery charge not going up. Pls help it's not even a year old.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
Sounds like a bad battery. When the battery will not hold a charge, and charges slowly it's a sign the battery is bad.
I did a search online an replacement battery and they run for ~$9.00 to ~$20.00.
这个答案有帮助吗?
得分 1
添加一条评论
It could just be the charger as well! Try with another one to see .
这个答案有帮助吗?
得分 1
添加一条评论
It looks like my battery has also failed after less than a year. There are YouTube videos that show how to replace one, but not being mechanically minded I'd have to find a shop to do it, or just get a new phone. Here's one of the videos: https://www.youtube.com/watch?v=yY8Gw1o4...
这个答案有帮助吗?
得分 0
添加一条评论
my battery is showing a exclamation on the battery saying 0% but its not dead and turning off and on while on the charger and turned off instead of showing a charging battery? any ideas
这个答案有帮助吗?
得分 0
1条评论:
As far as charging slowly. Try using a different wall socket ( outlet ). I don't mean to put a new socket in the wall. And only have your charger on that outlet. Nothing else plugged in. Get a good 5volt charger that puts out at least 1 amp and up to 2amps. Good luck
完成的
添加一条评论
添加你的答案
Rachel Carter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 4,982
