跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2692 个问题 查看全部
iPhone 6S home button and touch ID not working after screen replacemen
Hi, I've been repairing phones for a while. I repaired an iPhone 6S screen and attached the original home button to the new screen. However the first time I plugged it all in the home button worked but not the touch ID. I then unplugged everything to get the touch ID working, re- plugged the home button cables and now neither the home button nor the touch ID is working. Ive plugged everything in multiple times since. No difference. Any ideas? Also- the home button does seem to press down quite far however the screws are in as tight as they will possibly go and I'm not sure that that would affect anything? Any ideas? Thanks! :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
最有帮助的答案
I would try a new screen for starters. sometimes the ribbon cable behind the plate is bad in the aftermarket screens
这个答案有帮助吗?
得分 1
添加一条评论
I would recommend trying a different screen on the device, it might be a bad home button cable on the screen.
If it doesn't work on a different screen then check the button flex for any damage, if it is damaged then you will need to replace the button but you will lose Touch ID permanently
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cara 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 976
