跳转到主内容
Released September 2016, the Vivo 5R represents the sixth generation of the Vivo series and an update to the Vivo 5.
41 个问题 查看全部
Audio does not work at all
Has anyone been able to fix the audio issue w the BLU Vivo 5R? With the volume set to maximum you can barely hear the ringtones and videos are impossible. A few YT videos have suggested Engineering Mode & bring factory setting to max. It's suggested that instead of the audio range having a lowest & highest range, sometime a factory error will have both at minimum level. Please let me know if you have ever been able to get into engineering mode on this phone or have been able to fix the factory issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Simple solution after trying all sorts. Peel the plastic sheet off the back of the phone and over the speaker, Result loud and proud.
这个答案有帮助吗?
得分 4
7条评论:
I was thinking what a snarky little sh!t answer! Turned over phone and thought there's no sticker on the speaker. Who would do such a thing? Took off case ... oooooooooooooooooo myyyyyyyyyyyyyyyy gawwwwwwwwwwwwd nooooooooooooo waaaaaaaaaaaaaay!!! Peeled it off and will never outlive the embarassment LOL! You are a King - I'm just going to tell friends someone posted a fix. I'm never going to admit what it was LOL!!!
完成的
Thank you, thank you!! Just read this and was the same on my phone. I tried everything, adding volume apps, changing the settings in engineering mode and nothing happened! I was just about to send it back to Amazon for a refund. SO glad you posted this, as it is a brilliant phone!
完成的
Omg I done the same, I even phoned customer services, getting ready to send the phone back then read these answers, how stupid do I feel
完成的
Same thing here and used it for two months before reading this and seeing it was just the sticker over the speaker! TYVM.
完成的
My phone isn't in a case. So how to I check for a sticker
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Tim Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 7,995
