跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Replace Fusion drive for a SSD
I have a iMac 27" 5K (late 2015) 1tb fusion. (1tb hdd + 24gb ssd)
So I want to replace 1TB HD to Crucial MX300 SSD 750GB.
Will I need the "OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later"?
https://eshop.macsales.com/item/OWC/DIDI...
As I understand it, that is for Hard Drive upgrades, not needed for SSD. right ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, you still need the OWC in-line thermal sensor! It's not an issue of which kind of drive you put in.
While a SSD runs a lot cooler than an HD, the problem is the systems thermal management system depends on the input of the sensor to know whats happening. If you fail to replace it the system goes into fail safe mode running the fans at high speed and lowers the CPU's clocking.
这个答案有帮助吗?
得分 2
1条评论:
thank you dan!
完成的
添加一条评论
添加你的答案
Goyang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,237
