跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
wash machine has a error code of FH?
After the drum had been filling with water when it was off and put the CLR in the water hose. Now the machine won't run due to an error code of FH?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@ncitjb3 ,Todd, Did you turn your water supply back on to fill machine.
完成的
添加一条评论
1个答案
最有帮助的答案
FH seems to indicate that the problem is with the amount of water in the machine is not the amount the machine expected.
This link explains in some detail the issue and some possible fixes:
https://www.repairclinic.com/RepairHelp/...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Todd Blaubach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 3,060
