跳转到主内容
加入维修社区 - 创建账户
The HP Officejet 6600 Inkjet Multifunction Printer is a 4-in-1 device that can print, scan, copy and fax.
Why can't I print a card sized 4.9 x 9.8" using custom settings
why can't i print a card sized 4.9 x 9.8" using custom settings, i get a response that the printer does not support that size despite printing it on several occasions previously?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
How big an area are you trying to print? You may need to use the next smaller paper size, that should work. The only down side here is the larger margins.
这个答案有帮助吗?
得分 0
添加一条评论
You should be able to print that size, what may be going on is that the paper width needs to be 4.5" and length set to 9.5", you may have to change orientation from Portrait to Landscape.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Denise 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 125
