跳转到主内容
加入维修社区 - 创建账户
这是一款不锈钢 4 片式多士炉。型号位于设备底部。它仅有一个烤架高度,并配有一个可拆卸的碎屑盘。
Toast dial timer is stalling
The bottom dial ( the toaster timer) keeps stalling and won't turn off. It ticks for a while but stops after a while. The at times works if the toaster is upside down or it's back.
Do you need to change the switch? Or is there another way to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Happened to me too. It's a potential fire hazard when the mechanical timer doesnt shut off the oven.
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi Alfred,
I suspect you'll probably end up having to replace the timer, but you could try cleaning it. I would imagine there's a fair chance it may be gummed up with oils, carbon and all kinds of other volatiles from cooking.
Get yourself a can of electrical parts cleaner and spray the heck out of the timer. The cleaner will evaporate completely so there won't be an residue left in it when you hook it back up and try it. If there are any openings in the timer, use the red tube to direct the spray inside to wash it out.
Outside of disassembling the switch, which may or may not be possible, that would be my best suggestion.
Hope it helps; let us know how it goes!
这个答案有帮助吗?
得分 1
1条评论:
Thoughtful info, and so fast. Thanks!
由完成的
添加一条评论
添加你的答案
Alfred Assin 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 43
总计 1,325
