跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
iPhone 6s plus shuts Down after sim card
Hi :)
I have afsked about this before without any help so Im tryin again..
I have an Iphone 6s plus.. It Works fine and i Can use it whole Day.. But when i put a sim card in it, its shuts Down?? Sometimes in a minute, some times after 30 min.. It different.. Without sim card, it Works fine..
I bought the phone from a guy who has replaced the screen on it..
Can you say What it Maybe could be? Sim card reader? Antenna faulty? Dont know How important it is But the touch id does not work eighter.. Thanks:)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
You shouldn't put the SIM card in while it's on.
完成的
open the screen and look at the sim tray if its water damaged
完成的
Remove the iPhone 6s Plus panel and service the sim housing…..
完成的
添加一条评论
1个答案
已选择的解决方案
That's odd, there is no other question in your profile regarding SIM cards.
Have you tried using a different or new SIM card? The other possibility is that there are bent pins inside the SIM card reader and could be causing a short.
Open up your phone and inspect the reader.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
fixy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 412
