跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Even after replacing home button, its still unresponsive sometimes
I started having problems with my home button the other day. It only worked about 10% of the time, and didn't work at all for long presses. Touch ID also stopped working.
So I thought that I would go and replace the home button.
Ive now replaced the home button and it is still having the exact same issue.
It still only works 10% of the time.
I am now starting to believe that the problem isn't the home button, but somewhere the home button connects to. I don't want to have to replace the WHOLE front of the phone just to fix the home button...
Any suggestions?
This is a very strange issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Will my next best bet be to replace the LCD shield since it contains the home button flat cable?
完成的
Yeah. Anything more would be a logic board issue.
完成的
添加一条评论
1个答案
iPhone 6's home button has nothing to do with the screen. It's completely separate, the cable too I believe.
What exactly did you replace? The button? Or the daughter-board beneath the button? https://d3nevzfk7ii3be.cloudfront.net/ig...
If the button still works, but only "10%" of the time, sounds like it's simply dirty where the connection bridges.
If you can get to the mechanical switch (the clicky thing where the home button presses) when you take your phone apart, put a couple drops of isopropyl on to it (no less than 90%, 100% is best) and click it rapidly around 50 times.
Add another drop, click again. Then reassemble the phone.
这个答案有帮助吗?
得分 0
1条评论:
Yeah I figured that, but I found out you can get the LCD shied which has the home button cable running along it to the top of the phone by itself, so I was planning on replacing that next as that may be the thing broken?
I replaced the whole piece that you have pictured.
I have tried isopropyl around the button, but that did nothing.
You suggest that I apply the isopropyl to the actual clicking part? (which is the bit in the centre of the back of the button) ? I don't know how that would help as the actual mechanism seems to be inside that metal shielding?
完成的
添加一条评论
添加你的答案
calebmanley1996 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 81
