跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20001 个问题 查看全部
问题已关闭
Banded colors and lines on the LCD Display
I have a first generation MacBook Pro with an Intel Core Processor. The display has started to fail and will only render the image on one half of the display while the other half of the display is a solid band of white light. Squeezing the display housing on the left hand side will force the display to snap back into shape and render the full screen correctly. Releasing the bevel causes the screen to go half and half again. The computer hasn't had any physical damage done to it such as dropping or liquid spills. IT will push video to an external display and work fine so I know the issue is in the Display panel somewhere. What is the best quess on what part is failing and what I would need to purchase in order to repair the ailing machine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
On this MBP model the LCD inverter board is located at the front base of the display and the electronic board at the top rear side. Looks like the LCD electronic board is becoming faulty but you could try to open the display assy and install a spacer to compress a bit the board where the problem occurs. It could restore the video feed to the screen otherwise you'll need another LCD panel. You may also check the LVDS ribbon cable connection to the LCD panel, the cable could be bad seated in its socket but IMO the panel electronic board is the culprit and cannot be replaced since it's integrated to the LCD panel.
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,955
