跳转到主内容
HP Deskjet 3530 All-in-One Printer Series - Regulatory Model Number: SNPRH-1102
7 个问题 查看全部
Why does printer continue to jam after removing jammed paper?
Printer continues to jam when trying to print. This occurs after clearing jammed paper. Paper does not advance after being pulled into printer. Does not feed under rollers before ink cartridges.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
A very common issue with all printers is the rubber pinch rollers loose their grip from the paper dust so I would start off by carefully cleaning the rollers with cotton swabs (Q-Tips) and isopropyl alcohol. You may want to use a small paint brush to scrub down the parts and a can of can'ed air to blow the dust away. Just be careful you don't snag a part with the brush pulling it off.
Start there and let us know how it goes.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jeansheehy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 289
