跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
no front facing camera?
i just replaced my screen on my iPhone SE, and while the camera app does open and the rear camera works, the front camera is just black? I can press the shutter button but it will not take a picture. do i need to replace my camera or is there something wrong with the phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have the same problem, after second screen replacement Also, mic for Siri, earpiece and proximity sensor not functioning . The first time I replaced the screen on this phone, everything worked fine, even though I used a cheap generic replacement .
完成的
添加一条评论
1个答案
最有帮助的答案
Replace the front facing camera assembly, sounds like when you replaced it it was either broken or defective.
这个答案有帮助吗?
得分 1
6条评论:
thanks, but it is the camera that came from the iphone, i moved it over to the screen when i replaced it. it was working fine with the original screen. should i still replace it?
完成的
First, did you check if the proximity and light sensor is working? They are on the same cable and if they do not work either it could be a faulty cable or connection.
完成的
they are not working. is the connection bad in the cable or in the mainboard?
完成的
In other words, I should probably replace the camera, correct?
完成的
Yeah. If it was anything else it would be a logic board issue which is a bigger hassle to diagnose (one of the causes is a damaged front camera FPC connector on the logic board)
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Chloe sinisgalli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 153
