跳转到主内容
The Blendtec Total Blender is an all-in-one blender released in late 2004.
What's wrong with my Blendtec Blender?
My blender only runs for about 2-3 seconds. It's supposed to run for 2-3 mins. And it stops after 2 seconds and says "overload". Is it because of the speed sensor or the carbon brush?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
mine started to do that a couple of days ago and now it's out completely, how do i get it repaired? through the manufacturer? thanks I WANT MY SMOOTHIE! :(
完成的
Mine also says “overload” and there is smoke coming out of the rotor. Any ideas?
完成的
A few years maybe too late, but for anyone else who may stumble across this. Mine does this too. I found that if I FIRST - unplug the base, then remove the bottom and then the the plastic protective plate covering the motor the carbon brush has popped out. Once I push that back in everything is good to go until the next overload. Unless I am blending a really thick smoothie, it's not too often.
完成的
添加一条评论
3个答案
probably temperature probe is gone. its like when you use hoover for too long... but its just my wild guess
这个答案有帮助吗?
得分 0
添加一条评论
Hi, the problem is in the blenders rotor, it's shorted out. I can fix it for you if you have it.
这个答案有帮助吗?
得分 0
2条评论:
Francisco Aguila, what a great idea. How about you fix one and make a guide from it. Post it on ifixit, so we can all learn how to fix our blenders.
完成的
Hi Fransisco - where are you based? I have the same issue... would be interested in a repair as the blender only has 50 cycles on it!
完成的
添加一条评论
Try removing the bottom cover. Sometimes the cooling fan blade comes loose and the blender will overheat and shut down (and might display "overload" on the screen).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chuck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 40
总计 6,143
