跳转到主内容
Baby monitors manufactured by British Telecom.
8 个问题 查看全部
The handheld part of the monitor has stopped working
BT baby monitor and pacifier
The handheld part of the monitor has stopped working And won't even turn on with new batteries, not sure whether this could just be a fuse?
Also my other Bt baby monitor screen is just all messy and doesn't show anything and the volume won't turn down as much on the monitor part itself
Can I send them off to you for repair, is that something you offer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Hi @beckyp
Ifixit does not do repairs. Its' volunteers will give advice which hopefully will allow you to fix it yourself or they will recommend that you get it professionally repaired.
What is the model number of your BT baby monitor?
How long have you had it?
Has it been dropped at all and appears damaged or got has it gotten wet at any stage? This is only asked to initially eliminate potential causes.
完成的
The monitor which I am watching the baby from when I turn on it’s a completely white blank screen i can’t see where it needs battery has I’ve got a charger to charge it and it is fully charged but still doing it
完成的
Hi @ambermay ,
What is the model number of the baby monitor?
完成的
添加一条评论
1个答案
Contact customer support
https://shop.bt.com/Help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Becky kavanagh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 13
总计 1,263
