跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
over the time {20mins} it freezes. when cooled down, it works again
i have this macbook, off eBay. was sold to me as water damaged, but i cannot see a single sign of water damage on it, none of the sensors has been triggered. machine works fully, when started from cold. after aprox. 20 minutes, sometimes less, it just stops reacting on anything, it freezes and have to be switched off. if turned on immediately, it does not pass even boot process.
if left for some time to cool down, it works again, but again for only at most 20 minutes.
what could it be? i have already disconnected temperature sensor, the silver compound was applied, RAM modules reseated and also swapped from known working modules...
something burned out on motherboard? failing fan? maybe i was cursed by someone, in that case, do someone know some good priest? :D
thanks in advance for any help...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
There
could be damage under the board, or inside a connector... cleaning well with a soft brush and contact cleaner, followed by 99% iso-alcohol with 48 hrs drying time before applying any power may help.
Could be thermal paste (if disassembled and reassembled without new paste), or a shorted heat sensor or fan/switch.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 1
3条评论:
A good start--if this does not clear the problem obtain the original disk from Apple and run the hardware test with the computer cold. That might tell you whats failing. Appears to be heat related.
完成的
how do you do that hardware test? what do i need to press, when booting up?
i have noticed, when i use Fan Control, it lasts significantly longer...
完成的
添加一条评论
添加你的答案
palokiller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 1,230
