Galaxy Note 5 Wi-Fi and Bluetooth not working
My Samsung Galaxy Note 5 has problem with Wi-Fi and Bluetooth. Neither of them turns ON
I reset the device and didn’t work
The symptoms are: the Wi-Fi slide is OFF and grey, when sliding it to ON position it displays message “Wi-Fi Turning ON…” for few minutes and then it goes back to OFF; the same is with Bluetooth slide. I opened it to see if any wires were loose. All seems normal and all other functions of the device work fine.
Is it possible that the Wifi-Bluetooth modules are fried?
It looks like they are part of the mainboard. Can you suggest a diagnostic tools to determine if it’s in fact a hardware problem so I may start chasing the replacement part?
Thanks
2条评论
I think the microchip of wifi/bluetooth should replace it
由 Omar Zn 完成的
I accidentally dropped my Samsung Galaxy Note 5 and then the wifi and Bluetooth won't turn on anymore. What seems to be the problem? Can this be fixed?
由 Rob Roy Pausa 完成的
